Would it be a violation to run a bonding jumper from one neutral bar to the other neutral bar to bond each service neutral in the panel I changed the panel in the picture on the left the grounding retro conducted terminates on the neutral ball inside the panel on the right and I have to bond each service neutral I was thinking about running a jumper from panel to panel.
They allow us here to mount a external copper bus bar to terminate the grounding electrical conductor on it and then from said bus bar run jumpers to each panel usually we use a copper log with a nut and bolt I would assume running a jumper from neutral bar to neutral bar is basically the same thing
Sent from my SM-G986U using Tapatalk
