bonding metal boxes
tdawg
ok if u have a metal raceway ran from a feeder panel to a maybe a 12 by 6 can and ur feeding receptacles or lights from there via mc cable or Emt does that can need to be bonded or grounded. I see people who do and dont . Some say if u make taps in the can yes some say if its a straight pull no . Is ther a definite answer via NEC.:confused:
tdawg
yes junction box
yes junction box
Is the junction box not bonded through the metal Emt .Is that not a code wise good ground path?
tdawg
does voltage make a difference
whether or not its greater or lesser than 250 volts makes the difference
infinity
New Jersey
Journeyman Electrician
So this is what you have:
Panel feeds junction box with EMT-
From JB to various loads with MC cable.
The box is grounded via the EMT. If over 250 volts and concentric or eccentric KO's are used with the EMT than a bonding jumper is required. The EGC within the MC cables are required to be bonded to the box.
don_resqcapt19
Illinois
retired electrician
If there is an EGC in the wiring method it must be connected to the box even where the raceway is an EGC in itself.
250.148 Continuity and Attachment of Equipment Grounding Conductors to Boxes
Where circuit conductors are spliced within a box, or terminated on equipment within or supported by a box, any equipment grounding conductor(s) associated with those circuit conductors shall be spliced or joined within the box or to the box with devices suitable for the use in accordance with 250.148(A) through (E).
infinity
New Jersey
That is true if the circuit conductors are spliced. If they pass straight through then the EMT is permitted to ground the box.
peter
San Diego
I had this situation:
6 3/4" EMT coming into the box
~15~17 MC cables [various 12-2 and 12-3 and 12-4] going out.
All the terminations were at most 3 or 4 wires per wirenut.
Except I had about 22 ground wires to connect.
So I bought a ground bar and used that for all the grounds and simultaneously bonded the box also.
Question?
What if the box is plastic and the pipes metal? What if the box is metal and the pipes plastic?
~Peter
don_resqcapt19
Illinois
retired electrician
Peter,
Question?
If the box is plastic, then the conduits that are leaving the box would have to be bonded. If the raceways are nonmetallic and the box is metal it would have to be bonded.
Don
Bea
If you have isolated grounds they do not have to be bonded to metal box
don_resqcapt19
Illinois
retired electrician
Bea,
Yes, per the exception, but the box still has to be bonded to an EGC. That conductor may be the metallic raceway.
Don
a little more clarification, please
I have two circuits, both are 208/240, 3 phase, 4 wire, 60 amps. They both leave the power panel thru 1 1/4" EMT (8 wires total). The first circuit (4 of those wires) will wire nut at a 6" X 6" metal box and feed A/C unit one, where I will provide a bond between the box and the ground wire for circuit one. The second circuit will "pass thru" the first 6" X 6" metal box and, via 3/4" EMT, wire nut in the second 6" X 6" metal box and feed A/C unit two, where I will also provide a bond between box and circuit two's ground. Am I required to cut circuit two's ground wire in box one and ground it in box one, before sending it on to box two ? I read 250.148, and don't belive it requires me to, my business partner thinks otherwise.
LarryFine
Henrico County, VA
Electrical Contractor
Not if box two's conductors are unbroken in box one. With EMT and metal boxes, you don't need to bond either box (barring KO issues) at all, specs aside.
KOs in boxes manufactured today are listed as suitable for grounding means and are not required to have additional bonding means, over or under 250 volts.
Take a look at BGUZ for junction boxes and QCIT for outlet boxes.
Also reference 250.97 exception - the first paragraph.
infinity
New Jersey
No as long as the circuit conductors are not spliced and pass through unbroken. If they're spliced within the box than the EGC would be required to be bonded to the box.
250.148 Continuity and Attachment of Equipment Grounding Conductors to Boxes.
Exception: The equipment grounding conductor permitted in 250.146(D) shall not be required to be connected to the other equipment grounding conductors or to the box.
tdawg
grounded or ungrounded system
the nec code requirement you are referring to is correct via ungrounded systems not grounded systems
