- Tennessee NEC:2017
- Semi-Retired Electrician
The liner covers the shell, making it nonconductive.Liner is not the Shell. If line was synonymous with the Shell, it wouldn't be addressed separately in 680.26(B)
Suppose the metal structure is exposed on an above ground pool with a non conductive liner. The 2023 did away with the depthThe liner covers the shell, making it nonconductive.
Pool, Storable; used for Swimming, Wading, or Immersion (Storable Immersion Pool). (Storable Pool)
Pools installed entirely on or above the ground that are intended to be stored when not in use and are designed for ease of relocation, regardless of water depth. (680) (CMP-17)
Most AG pools are not designed to be storable, or moved. They could be with a lot of trouble that on one would do. There is sand beneath them and that would have to be dealt with.Suppose the metal structure is exposed on an above ground pool with a non conductive liner. The 2023 did away with the depth
This around me is a an exception.Most AG pools are not designed to be storable, or moved. They could be with a lot of trouble that on one would do. There is sand beneath them and that would have to be dealt with.
Not saying there aren't any, but every AG pool I have seen, or wired for, the outside is covered with vinyl, or plastic. I suppose if the outside was metal and totally exposed you might need to bond the 4 points.
Here is a pic of one. It is being taken down soon, but you can see the outside is covered, including the top rail.
The only pools I've dealt with that have any metal exposed are ones that are called "partial in-ground". They have part of the pool in-ground, usually the deep end, and part above ground. These I do bond at 4 points. The one I showed in the pic is the norm around here for what is called an above ground pool, and the 4 point bonding is not required.This around me is a an exception.
Most I've dealt with are galvanized or Aluminum metal exposed shell, some even having metal deck surround. Some might have a vinyl edge that keeps the vinyl liner up by pinching the liner to the metal framing and shell. It will even be able to have continuity on a VOM between the metal components, one side to the other, so you would tell me it doesn't need bonding. Water is bonded and you would have a difference of potential if the other metallic components are not.
Most around me are like the last two in this post on previous thread: https://forums.mikeholt.com/threads/pool-bonding-lugs.2582244/post-2935596
