Are the walls of the pool 42"?
If they are taller , this would not be a storable pool.
I have never wired an above ground pool with walls 42" or less. This is a big problem because now many of us would need to create the equipotential bonding grid under this thing and extending 3' from the pool , also many of these pools use plastic uprights between the metal track that holds the pool wall top and bottom. The top track is touchable from inside the pool , the last pool like this I wired had no continuity between the track sections , so to comply would have meant bonding every section of wall track top and bottom.This is very difficult to do with the wall in place . Also the bracket at the top and the bottom of the upright had no screws to connect the track , it was a preasure fit ,again providing no continuity .
I am sorry to say , I called it a storable pool and my fingers are still crossed , I hope the damned thing collapses , while no one is in it of course
