chicago-tony
Explain what is meant by voltage gradients? Bonding a in-ground pool. When are metals of the pool are bonded with a soild number #8 copper, I was told to start from the motor and bond all parts them run the #8 to a ground rod and drive it into the earth at least eight feet. I told the buidling offical that I did not have to drive a ground rod and attach the #8 soild to it. Can someone explain? Also, a pool from pool-o-rama in chicago, the outter rim of the pool is metal so I bonded that and the inspector to me that I did not have to bond that.
