Because of differences of oppinions I need some feed back. A transformer on the 2 level is feed from a disconect from the basement /electrical room. The cable feeding the primary is going through a 2 inch EMT riser. That EMT was bonded with a #3 ground. There are 2 more EMT risers( also 2 inch each) next to the 1st riser. These 2 additional risers have cables running through them from a main panel to subpanels on different floors. I do not believe these last 2 risers need to be bonded as it is not part of the service and it is only for protection only and to make it look better.
If anyone can shed some light on this please let me know.
Thank you
Thank you
