There is uncertainty about how to bond to the tub. The NEC is a bit unclear as to what is acceptable so we are looking for some insight form those that may have solved such a problem. There is nobody in The Boise area that performs exothermic welding so that options seems to be out. The only metal on this spa is the stock tank shell...no lights, ladder, hand rails etc. The equipotential grid has been laid with #8 copper made for this purpose. Copper #8 has been pulled from the equipment utility room to the tub in underground conduit ready to bond. However, there is uncertainty as to properly bond to the tub. Welding (e.g. a stud or lay in lug) seems to be frowned upon by the inspector because of the dissimilar metals being used. Any advice you have have or "goto" sources would be appreciated.
