the transformers I have installed all passed inspection. On most instalation we use Teck Cable as a feed from the splice box connected to the main disconnect. On the Teck we strip the outer jacket so that the dry connector grips the aluminum sheeting. I would say the alluminum sheeting on the Teck Cable is bonded and protected by the dry connector connected to the transformer casing. The cable also has a ground wire inside. Does anyone use ground bushing on the dry conector that brings the Teck Cable in the transformer?
