I've got an Industrial Control Panel with a 480vac/3 phase/60hz feed coming from a power distribution panel. There is a power transformer inside the panel that drops the voltage to 120vac. The neutral and ground are bonded on the transformer, and the neutral is terminated at the ground bar on the backplate of the panel; which is in turn connected to the incoming grounding conductor. Is this permissable? My interpretation of Art. 250.30 (A) is telling me that it is not, but I need a definitive explanation.
