Wednesday, June 24, 2015
Question:
Re: COD answer published Monday, June 15, 2015 - Likely to become energized
Charlie,
Would you like to address the meaning of "likely to become energized"? In my opinion, non-current carrying parts of equipment are never "likely to become energized". Sure they may become energized but that is not "likely".
Full Definition of LIKELY
1: having a high probability of occurring or being true: very probable <rain is likely today>
I think CMP 5 took a step backwards as far as the enforcement of the bonding rules, when they changed the wording from "may become energized" to "likely to become energized". Anything thing that is conductive "may" become energized, but it is not "likely" that they will become energized. Under the code wording, things that are not likely become energized are not required to be bonded.
Don
Answer:
Hey Don it's good to hear from you and thanks for your comment.
The words "may" and "can" are sometimes used interchangeably in the English language, Maybe learned from children's games like "Mother May I" then later in life to "Bartender may I have another can of beer". Can is also used to mean that something is possible to happen.
But back to the NEC concept, the NEC Style Manual (available at nfpa.org, under the codes and standards tab) in 3.1 states that the terms mayor can shall not be used in mandatory rules. In 3.2 it states that "The term "may" shall only be used where it recognizes a discretionary judgment on the part of an authority having jurisdiction." So the change in 250.104(B) of the 2005 NEC to replace "may" become energized" with "likely to become energized" complies with the
NEC Style Manual.
Additionally guidance is given in in Annex B, Standard Terms, of the NEC Style Manual, "likely to become energized -- failure of insulation on"
So I think the phrase "likely to become energized" is appropriate if we consider that insulation (including the air) can eventually fail leading to conductive objects becoming energized. That is considerably different than stating what may or can become energized as anything conductive can become
energized, but that is not likely, therefore bonding is not required in that case.
