mbrooke
Batteries Included
- United States
- Technician
:lol:
Ahh ..... I don't think I am on his Christmas card list either.
Darn
:lol:
Irregardless of being designated an earth electrode or not, this is definitely one way steal can become energized.
I have a table lamp sitting on top of a metal filing cabinet. Conceivable I could close the cord in the drawer and energize the cabinet.
Should the NEC require bonding of metal furniture or should I just receive a Darwin award and the rest of the world gets on with their lives?
BTW, that rule is not about structural steel, its wall framing.
True, but this proves my point, it should not matter if building steal is an electrode or not, it should be bonded. Why do we bond water pipes then?
And again I ask you should we bond my filing cabinet?
How long have you been here that youi have to ask that question?How the heck did a thread go from ufers to open noodles energizing filing cabinets?:blink:
How long have you been here that youi have to ask that question?![]()
In theory yes... but there is this: will your filing cabinet become energized during an open neutral?
mbroke said:True, but this proves my point, it should not matter if building steal is an electrode or not, it should be bonded. Why do we bond water pipes then?
Hold on, try to focus.
You were hanging your hat on the appliance installer getting electrocuted by the metal studs as proof building steel should be grounded. That incident had nothing to do with neutrals.
So I asked you about my filing cabinet and you jump back to open neutrals.
My point is simply this, we cannot protect against every possibility.
Dependent on where the human is and where the neutral opens, bonding anything to the neutral can hurt as much as help.
You mentioned plumbing, yes we bond it, and when I am in the shower that may save me.
When I standing on wet ground shutting off my outside hose faucet that bonding may kill me.
Yes, because there would be less need to bond a filing cabinet because the risk is lower:
A. Filing cabinet energizing risk:
1. Local lamp cord may get pinched in the door.
B. Building steal energizing risk:
1. Hundreds of not thousands of square feet of wire that could enrgize a stud at any point
2. Open neutral
3. MV falling into LV on the pole.
Of course, but we can go after the most likely ones
That is true, but if everything is bonded together, mainly the major components a person is likely to be in contact with (like a floor with rebar), the risk is reduced.
Bonding only one side or failing to bond the stair into a pool can be dangerous, but once both rails are bonded with everything else it becomes safe.
But unbonding plumbing creates a bigger risk only because a person is more likely to be inside the structure when touching plumbing then outside.
I am going to consider this a non-response.![]()
BINGO!!! But you have not shown it is likely only that it is possible.
So now you have made the jump from bonding building steel to making the entire structure an equal potential grid.![]()
Now the mailman walks up to my home, grabs the railing and gets knocked on his butt. Maybe a grounding mat for my yard is needed as well.![]()
Using the pool example that you seem to like, my cabinet would have to be bonded.
No kidding, I thought we already established both of us understand difference of potential.![]()
[/QUOTE]I take you do not work well with probability?
The problem is you are not using any facts, you are simpley making assumptions.
That is no way to write code.
I have some errands to do, I will keep reading from my phone but to tough to make quotes with.
What is your experience in that? I think you would contribute a lot to the discussion.
Cattle either loosing weight because they aren't drinking water, and/or lowered milk production Mr MBrooke
The internal influences can be mitigated by bonding ,ergo the equal potential in art 547, (or 680 if you will)
This works to an extent , because the earth conducts , electric fences being a notorious culprit.
The external influences would be the entire poco infrastructure's MEN . Yes they can install isolators , but they only work IF any given equopotential plane is distal from the next one.
Fact is, the closer one drives a GEC to a substation, the more likely it is an earthed noodle....![]()
If we want to truly examine our GEC's ,UFERS, or what some (thankfully) call Earthing, we need to consider the different styles OF earthing out there
~RJ~
