marpar
New member
- indianapolis, indiana
I am installing a 60 amp 480 volt disconnect in our factory that feeds (3) 30 amp 480 volt disconnects for feeds to 3 battery chargers. The 60 amp disconect is being fed from a factory buss plug system that feeds all sorts of equipement. A co-worker & I got into a disagreement on weather bonding bushings should be used since we pulled a ground conductor thru-out the system & grounded it at each disconnect & ties directley back at the bussway system. I said it wasn't necesary since we are not using the conduit as a ground. we are using siemens fuseable disconnects with eccentric k.o.'s with double locknuts & ridgid conduit pipe. they are mounted on metal framing with multiple grounding contacts thru-out. The way I understand the NEC book is that it is nit neccesary when the pipe, raceway, etc. is not being used as a grounding system. please help. Marty
