Bonding without sepearte EGC in subpanel
jzimmer238
New member
My home was built in 1994. The utility pole is 70' from my house. At the main panel at the pole the ground and neutral are bonded. A 150A breaker feeds a subpanel at the house through 3-4/0 AL conductors running underground without conduit. At the supanel in the house the the neutral and ground are bonded. A #4 bare copper wire runs from the neutral bar to a ground electrode. Should the ground and neutral be isolated? Does a seperate EGC need to be ran back to the main panel.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
Chris
