Booster pump
hhsting
Glen bunie, md, us
Junior plan reviewer
I have domestic water booster pump 480V, 3 phase with (3) 15HP motors being fed by single 90A breaker size.
I am not sure but is 90A breaker correct size? Would 430 or 422 come into play? What would be correct breaker size?
Art 430 would apply.
Ate you askimg about the feeder breaker for all 3 pumps ??
You tell us what breaker you think would be correct and based on what Code Section !! (Only way you will learn)
Then we will comment
From switchboard I have branch circuit breaker feeding the booster pump that contains or has quantity 3 15hp motors.
430.52?
I have 90A breaker from switchboard to domestic water booster pump model Alyan VSPMT-275115-3-15, qty (3) 15HP located in Fire pump room. Its triplex pump all tie to control panel. All can be run same time. Do I use one motor or all motor to size breaker?
Is it 430.52?
Make model does not matter, need name plate data.
Its not installed in field. All the items I post they are on plans. However this booster pump triplex is new
Schedule for it just shows (3) 15Hp, 480V, 3 phase, 60Hz thats all
Other than showing the correct method for calculating the breaker, this may all be a moot point anyway.
If you are reviewing electrical plans, what size conductor is the 90 amp breaker protecting ??
In my state, we only have this level of plan review for hospitals and schools. The field AHJ looks at and approves
The single 90A breaker in the distribution panel cannot be the branch SCPD for those individual pumps, it is a feeder to them. Assuming, because it is a “triplex” pump panel, that they are operated from a control panel, each pump controller would require its own branch SCPD (breaker, fuses, motor protector). Hopefully that’s what they are providing and if so your breaker will just be a feeder. If not, and they want 3 non-combination starters hanging on the wall all protected by just that single 90A breaker, that isn’t going to fly.
