dbuckley
- Canterbury, New Zealand
There is no incoming neutral. There is just 480 three phase with a grounding conductor. Is your concern still valid?
Nope. Its carts with neutrals and improper grounds that are the risk.
Just checking though: as the receptacles have a ground pin that works and there is a transformer in the cart you have a SDS, and therefore the receptacle grounds should be connected to the ground supplying the cart.
