tonyi
Re: Bootleg grounds
Originally posted by iwire:
Tony.
BX is not listed in 250.118 as a grounding means and 250.114(3) specifically says information technology equipment must have a grounding means.
Indeed. Not many homes wired with BX I've ever seen would qualify to have Article 645 applied to them though. A PC in the home isn't "information technology equipment" IMO, its just another piece of electronic junk people plug in.
Q: how many external modems and computer gadgets with external bricks come with a 3-prong that propagates a gnd to the device?
A: vanishingly close to ZERO. This crap is just ordinary home electronics, not an effing megabuck mainframe. Get real eh.
How does the homeowner know which 3 wire plug is a "reference ground" and which 3 wire outlet is a equipment ground or even know what the difference would be.
They won't care, or need to know. ALL installed 3-prongs would have metallic connection back to the panel via backstrap and mounting screws even though you don't land a gnd wire in the boxes. If that BX is a good enough conductor to heat up like a fillament on a fault, its good enough for an electronic gizmo's reference gnd.
If the NEC even talked about a reference ground on a branch circuit.
Indeed. Perhaps because its not a SAFETY ISSUE. The NEC doesn't address a lot of things. That doesn't mean they aren't possible or won't work. The NEC doesn't have much to say about LAN's that modulate on the building power circuits either.
Your a trip Tony, a little voltage drop and you think the world is ending
Well, there happen to be NEC guidelines for Voltage drop. Feel free to ignore them as you see fit, I don't.
, you think the NEC is 20 to 30 years behind,
That some people routinely trip breakers on a code minimums installation while doing pretty ordinary stuff supports my opinion.
some paint on the face of an outlet and you say a violation that must be corrected,
That's what the book says. Take it up with the CMP's if you don't like it. I didn't make that passage up.
but no equipment ground at a 3 wire outlet is OK.
Again, that's what the book says. Again, take it up with the CMP's if you don't like it.
