Bored holes in steel support beam.
spsnyder said:
Quote:
. . . and closest to a column or wall.
Wrong!
The middle third in both directions is the safest area to penetrate.
Larry,
Are you sure. The largest moment on a horizontal beam is in the middle of the beam. The closer you get to either support the less the moment.
Thanks.
Yes, I'm sure.
The center of a beam is where the greatest stress is on the edges; top has most compression and bottom has most tension.
The web has the least stress.
The ends are where, as Paul stated, the greates shear force is concentrated.
I see your points and looked a a free body diagram with a universally distributed load and see what you mean Thanks for the insight.
