- Massachusetts
splinetto said:IMO faster doesn't = better
Never?
I think faster can result in equal, better or worse it depends on many factors.
I don't see anything inherently 'poor quality' about running more than 1 NM per hole.
splinetto said:What is the problem with drilling a Hole for every wire? I'm sorry But when I see multiple wires in a single hole it just doesn't look right. How do you pull them in without damaging the sheathing? I guess when in Rome do what the Romans do.
Oh Im not fast I just do it right the first time. I dont like to use my drywall saw like some people do.480sparky said:Means I ain't no spring chicken. I don't go balls to the walls like the young bucks do.
Mostly Yes and and when I put two thru 1 its only 14 and the rx connector is listed for 2480sparky said:Do you land each cable in the panel with a seperate Romex connector?
LarryFine said:In my opinion, these two situations should be treated differently.
splinetto said:I guess it just really depends on where you learned the trade. Maye if I learned in an area that practiced pulling multiple cables I would think that drilling a seperate hole for every wire was crazy. Even the shady shops around here don't do it.
I'm the opposite (I do pull homeruns first though). How many spin boards do you have? I might use 2 spin boards but it has always been 1 at a time.andinator said:The guy who taught me how to pull romex would yell if I had one in my hand when I could have three. He also taught no more than three wires per hole, no reason given and no questions asked at that point. When I'm roughing a house I pull homeruns first so I can open every single roll on the van and pull all them suckers at once!!!
splinetto said:Even the shady shops around here don't do it.
I'm saying that it would't fly around here . It would get turned down in a second.iwire said:Say what?
You would not be implying more than one NM per hole is so bad that even 'shady shops' don't do it?
splinetto said:I'm saying that it would't fly around here . It would get turned down in a second.
I would get fired after i tore it all out and fixed it.splinetto said:If i wired a house like that I would most likely get fired. It probably sounds crazy to you but that is how we do it here.
splinetto said:I would get fired after i tore it all out and fixed it.
splinetto said:It is the norm here from the city to the rural areas. It is not just one inspector it is multiple juridictions of inspectors.
