- Placerville, CA, USA
- Retired PV System Designer
While you are actively boring, the flow of water is coming back under some pressure along the path of the pipe, keeping the fill from settling and lubricating the outside of the pipe.I have used same method in sandy soil and went maybe 50-60 feet with 2 inch PVC before. You need to use same pipe you intend to leave in place in that kind of situation as it likely will not pull back out.
Once you break through at the other end this effect stops, so either pulling back or advancing the pipe further will become very hard.
And once you let things settle and the water in the fill around the pipe drains away, you will find the pipe very well locked in place.
