Box back wire
wireday
New England
Master electrician
Are we ok surface mount a 4 square steel box through sheet rock into a wall stud, then bring a wire into the box from a knock out in the back of box ?
zooby
Indiana
maint. electrician
not sure if there are firewall considerations but as long as you are using correct fittings etc...yep.
Fred B
Upstate, NY
If box is secured to the framing members this can be done. But why a 4sq? If this space is finished (suggested by presence of sheet rock) I would be using a "Wiremold" box. Designed for rear entry and a finished look.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
You should have no issue but a recessed box fastened to the side of a stud would look a lot better. Get a gangable 3 1/2" deep box if you need more gangs.
