SEO said:How would you ground it per section 250.4 (A) (5) ?
What happened to the ears/wings on the old work plastic box?j rae said:can you use a metal madison hanger on a plastic old work box??
celtic said:Is a madison bar "likely to become energized"?
I am thinking of a madison holdit that is used for holding gem boxes in. Which could become energized if a device screw or bare conductor touched it. I guess I don't know what a madison bar is.
Probably the same item with a bunch of different names:celtic said:Is a madison bar "likely to become energized"?
SEO said:I am thinking of a madison holdit that is used for holding gem boxes in.
Sure it could become energized ~ but is it "likely"?SEO said:Which could become energized if a device screw or bare conductor touched it.
Thats the same thing I was thinking of and I agree with your reasoning. Also metal switch plates have to be grounded and they are less likely to become energized than the madison holdit.:smile:celtic said:Madison Hold Its
If installed properly, no.
Installing one on a plastic box, IMHO, is not a "proper install".
I'll try and find a pdf or something on them....
SEO said:Thats the same thing I was thinking of ...
Huh? You found an 8x8 with plaster ears? :-?mattsilkwood said:has anyone seen those in different sizes? i had to make some for an 8x8 that had to be recessed a while back.
No I didn't look .:smile:celtic said:...did you find a pdf or something![]()
I'm having a good time jabbing at you. All in fun.:smile:celtic said:We're getting nowhere quick here![]()
SEO said:I'm having a good time jabbing at you. All in fun.:smile:
I always call them "2 men in a boat"...JJWalecka said:"Madison Straps" or "Mad Bars" but never heard of "Battle ship".
Justin
Hey you left out madison strap, which by the way is the only name I know or have heard it called until now.celtic said:Probably the same item with a bunch of different names:
Madison Bars
Madison Clips
Madison Hold Its
F Clip
Battle ship
etc
not only that but I thought all 8x8's have a bent in lip all the way around with the four screw holes for the cover, which seems like a madison strap would not be able to even fold over the box.mdshunk said:Huh? You found an 8x8 with plaster ears? :-?
Sure, you could. It would bend over the front lip, around it, and tucked into the inside of the lip's fold. A 90, a 180, and another 90.steelersman said:not only that but I thought all 8x8's have a bent in lip all the way around with the four screw holes for the cover, which seems like a madison strap would not be able to even fold over the box.
