Sure. Might look pretty ugly compared to a hex nut. You could always put the wings on the inside.![]()
Will the wings count towards the box fill??:happyyes::happyno::?
Moot point since there will be no cover due to the length of the toggle screws![]()
The box will be installed in a elevator shaft.Can I use a toggle bolts to faststen a four square box to a metal L bracket ?
Can't see it from my house. Thanks!
Nobody says you have to use the bolt that comes with the toggle.Moot point since there will be no cover due to the length of the toggle screws![]()
I've used toggles when I had no way to get a wrench or pliers on the nut.
Well, if we're going to be serious or practical:I can snap off 3/16 or 1/4X20 bolts all day long with my pliers. They usually break right at the edge of the nut too.![]()
