vinnygalbo
Banned
I have a VFD with a braking resistor unit attached.
VFD - http://shop.actechdrives.com/AC-Tech-Lenze-ESV752N04TXB-p/esv752n04txb.htm
Braking Resistor - http://shop.actechdrives.com/AC-Tech-Lenze-845-415-p/845-415.htm
If for some reason the braking resistor fails, should I still be able to run the motor with this VFD? or will the VFD give me an error message?
If I can run the motor without the braking resistor, is there any danger to the VFD or motor being damaged?
Thank you
Thank you
