Where is the branch circuit going? If it is going to the mobile home then I say violation based on 225.30 but if it is going to a separate structure then there should be no issue.I want to run an outside branch circuit from a mobile home disconnect. The service is over 50' away. The circuit would be run from the second required disconnect (within 30' of MH). Is this code compliant? Thanks
