I have a pole mounted meter/panel combo about 30 feet away from a small utility shed that exists just to house a well pump and pressure tank inside. I need power to to this shed only for the pump motor inside and also would like to bring a branch circuit over for a receptacle and small light for inside. Does this small building need it's own sub panel or can I simply bring 2 circuits over from my panel on the utility pole? Do these branch circuits need a disconnect on or at the building even thought the breaker is within view?
Was planning on bringing circuits underground in pvc to the inside of the shed and hitting a junction box. There is another building that will be built in the future that will need it's own sub panel that will also be fed from this meter/panel combo on utility pole, not sure if that's relevant in any way.
I mostly do industrial work so this is a little out of my area of expertise but I'm helping a friend out with their project. Any help is appreciated.
