jmsbrush said:The numbers that are being discussed in Franks article is that for service calls only? Or is it for also when you bid out work lets say a Walmart or gas station?? Lets just say 15000 hours for pretend
Those numbers are based on a service type business, If you were doing new construction, you have more billable hours in a day, less overhead ( less trucks, insurances, fuel etc..)
The same rules would apply but your rate would be reduced (if you desired)due to more billable hours and less overhead
