I received a call for a home without power. I have something odd taking place and don't know of any solutions here and need some suggestions on this one. I will give you facts then some pictures.
Information:
125A Breaker using 3/0 Aluminum when 2/0 is the requirement. Aluminum has 0 give as they left no extra wiring at all and they gave the wire a hair cut to fit into the breaker causing it to arc in the terminals of the breaker. It melted some of the undersides of it. For testing, I replaced the breaker as I wasn't getting voltage from the terminal to ground indicating bad breaker. After testing I noticed 0 volts when testing across L1 and L2. Here are the photos and tell me what you think.
Information:
