sceepe
Do you guys think there is any need to worry about breaker coordination at currents above the available short circuit current. (Assuming you have to worry about coordination in the first place?)
IMO you don't; but the available current may depend on the type of fault. Coordination needs to be correct reguardless of the type of fault. If your coordinated with the worse case fault is that good enough?
Semi related question: Why don't the gear manufactures have tools (software) avail to easily coordinate their products?
