RoyIV
New member
- Rio Linda, CA,95673, USA
I have a customer that asked me to check out a rooftop HVAC/Heatpump unit feeder supply. Apparently the feeder trips when it is cold outside (We're in CA...so..."cold" = about 40F out here...quit laughing, please!). At any rate, the breaker would not trip while I was present (I waited about 1 hour) and the ambient temp was about 68F while I was present. I logged voltages ph-ph(215v, 215v 216v) & ph-gnd (216v, 214v 215v) -acceptible values. I meggered the wires ph-ph & ph-gnd & also achieved acceptable values (almost infinity in all cases). The feeder = 50A 3pole breaker & #8Cu wires (less than 125 lineal feet of conduit run)...The owner had previously called a HVAC contractor to come & troubleshoot the unit, The HVAC service-call paperwork had information written on it...(all though it was chicken-scratch). The notes stated that while the unit was operating -with heater strips on- that the unit was pulling "over 40A" ( yes... the HVAC service-call representative DID NOT write the actual value, he/she simply wrote "over 40A"). The HVAC service-call representative diagnosed that the feeder breaker was warm to the touch & was bad. Although the heater strips were not "on" while I was taking data- I witnessed no "warm" ckt breaker (ph-ph amps @ unit disconnect = 19.0A, 19.6A, 13.5A). This HVAC unit is quite old & I cannot find any nameplate data on the unit. I found a heater assy sticker that reads= Allied/Carrier model 88EM0100EA00...so...I'm guessing that the unit is a Carrier50QQ. This is a complete guess. What I'm letting you know is that I dont know what Max OC protection or min ckt amps should be-according to the manufacturer (all the stickers & nameplates are gone). At any rate, I got to thinking about the big picture. Quite often I'll hear a client, a general contractor, or a member of another construction trade state that "the breaker is bad" or "the fuses are bad". I have to say that it has been my experience that 99% of the time...the breaker/fuses were working exactly as intended. I realised that -technically speaking- my knowledge of breaker internal operations is pretty limited....
My question (Finally, I know....): If a 50A 3pole breaker is subjected to a constant load of lets say....45A (well in excess of 80%) would it be normal expected operation for the breaker to trip after a given time period?
