Hi all,
So we designed a system with 2 x 3800W inverters (20A breakers each for a total of 40A) with the PV breakers in a 125A sub panel. The sub panel is being fed by a 60A breaker in the main panel which has 200A bussing and a 200A main breaker. I get the 120% rule allowing us the 40A of PV (which we have) but the plans examiner says that the 60A sub feed exceeds this rating. The reason we went with a 60A sub feed breaker is in case the homeowner wants to add an EV circuit to the sub panel in the future.
The way I understand it, this circuit will never be more than 40A (PV). Right?
The label in the main service panel allows for up to a 110A branch breaker. Isn't the 60A sub feed essentially a branch breaker. Even if the homeowner were to add more circuits in the sub panel they would be loads and not a source (like the PV). We used #4 AWG for the sub feed so we're good to go as far as amperage is concerned.
Can anyone give an answer or point me to a section of code regarding this? It would be much appreciated.
Thanks!
Thanks!
