I want to verify if the correct breakers are being used for a swimming pool in Georgia.
Attached is a picture of the breakers that are being installed in a Hayward OmniPL control. I looked at the manufacturer electrical wiring instructions and regarding the use of GFCI breakers, it says to follow local codes but does not say they are required. There will be a 100A main feeding this control which is yet to be installed or of known type.
As for equipment that will be powered:
2.7hp 240v water pump.
Booster pump, voltage unknown
Low voltage transformer
Heat Pump 240v
Eaton breakers are used but not listed in the chart below as suitable although all are BR prefix
For the heatpump, it is a Siemens and neither the mfg or type are listed as suitable.
Heat Pump 240v
