- New Jersey
- Journeyman Electrician (retired)
It's tricky because you don't know if a smaller OCPD will allow the motor to start. There is really no answer other than maybe real world experience with this motor type. You can also do as kwired suggested and use a motor circuit calculator and see what that suggests.If code allows you 150 amps breaker size for this particular motor, but i can use a 90 amp breaker, how do u determine that? I mean that's a big difference in amps and $$. As I see this as long as the conductors are protected, and the breaker size doesn't fall under the conductor amps, I'm ok??
