Hello,
I was called to an office building today that had lost all their parking lot lights. I quickly discovered that the breaker had tripped. The lights are 480 volt, so I didn't want to be too hasty to reset the breaker. I disconnected the feeds from the contactor and used my Fluke to check for a short or a ground fault. I found none, though I did measure some ohms between phases, as I expected. I reconnected the feeds, reset the breaker, turned on the switch at the time clock and the lights came on. They burned for about an hour until I turned them off and left the site. Any ideas as to why a breaker trips for no apparent reason? I suspect a bad ballast, but only because I can't think of any thing else. Is there a better troubleshooting method to follow? Thanks for any help.
P.S. : I know someone will ask : No, I wasn't wearing any PPE when I reset the breaker and turned on the lights.
