mkgrady
- Massachusetts
I have a customer that has air blowing in through the outside walls through receptacles and switches. She lives right on the coast so the wind gets pretty strong. The walls are wood studs, plywood sheathing and drywall with fiberglass insulation.
She tried using those foam pads that fit between the plate and the device but it does a poor job of slowing down the air.
She had a insulation installer check it out and he recommended she spray foam insulation in to each device box on exterior walls. She asked me what I thought and I said it sounds wrong to me.
Anybody ever hear about this fix? If this method doesn't make sense, as I suspect, does anybody know of a good way to slow down the air?
