The modules communicate with the transfer switch with the neutral. Each module must me numbered in sequence of preference to be turned on between 1 and up to 8. If it is on 9 then it will be locked out during an outage. The modules monitor if there is enough power from the generator to turn the large appliance on. It starts at 1 and then 2 and so on. If a larger appliance turns off, say the oven, then another larger appliance can turn on. All of this is done in 5 minute increments. To me it looks like a range circuit board issue. You can bypass the module if need be. I've done it before waiting on a replacement module.
