Yes, V line is greater than V bus only near peak. At issue was whether it is always correct to say that is the only time the diode will conduct.that is not what was being discussed
V line > V bus only near peak V line
that is correct, not incorrect
And that what seems to be getting ignored or maybe just not understood.Yes, V line is greater than V bus only near peak. At issue was whether it is always correct to say that is the only time the diode will conduct.
V diode is not always V line minus V bus when there are other elements in the circuit.
My posts seem to be "going away", being disappeared. I wonder.......disagree
the statement was conduction occurs at peak, V line > V bus
this is true, not "incorrect"
this accurate for the vast majority of commercial vfd's
If you can manage with only inductors and no capacitors in DC link, on output filter etc in your converter, then 120 degree conduction angle is possible imo.My posts seem to be "going away", being disappeared. I wonder.......
Anyway, we were making commercial variable speed drives from the early seventies, usually for industrial applications. Had they not been commercially viable we wouldn't have been commercially viable. Three phase converters had a 120 degree conduction angle. That was the basis for the semiconductor thermal calcs were done to size them, the heat sinks, thermal switches, enclosure ventilation, and cooling medium* flow requirements.
*Mostly it was forced air but on some of the bigger units we had de-ionised water and on the higher voltage units (up to 11kV) we used silicone transformer fluid.
Horses for courses.............![]()
It isn't just possible. It works. With both.If you can manage with only inductors and no capacitors in DC link, on output filter etc in your converter, then 120 degree conduction angle is possible imo.
Any diagram?It isn't just possible. It works. With both.
Unfortunately I had a computer failure and lost a lot of drawings. But it is fairly simple. The inductor is in series with the DC and the capacitor is across it.It isn't just possible. It works. With both.
Thank you for your polite and considered response.Besoeker: in the drives you describe, with input rectifier conduction angle of 120 degrees, I presume this is at full load. I would expect the conduction angle to decrease at partial load, as the DC capacitor retains voltage exceeding portions of the AC supply
-Jon
Is there any confusion between unfiltered three phase converter in which conduction angle 120 degree and filtered three phase converter in which conduction angle less?It isn't just possible. It works. With both.
I've had dealings with/designed different sorts of variable speed drive systems. Most, if not all, have some sort of filtering even if that is the motor itself.Is there any confusion between unfiltered three phase converter in which conduction angle 120 degree and filtered three phase converter in which conduction angle less?
Given a conventional diode rectifier (no gates, no control circuits...) and a capacitor filter, the diodes only conduct when forward biased, and thus current only flows when the supply AC exceeds the capacitor voltage. In small systems with big filter capacitors the diodes very clearly only conduct at the 'peak' of the AC cycle.
-Jon
