In 250.50[2] Metal Frame of the Building or Structure for a grounding electrode system is every column of the building required to meet one of the three requirements? For example I am working on a project with a building addition [no ground ring / counterpoise was indicated], the drawings indicated to provide grounding "as required" so to meet 250.52[2] using [2] Connecting to the reinforcing bars would it be require to provide this connection at each metal frame [column] through the building? And if the 20' of bare copper is used is it acceptable to "coil" this up at the bottom of the footing / foundation [as one of the typical detail indicates it this way]?
