peterlonz
New member
- Queensland, Australia
Store lighting
Store lighting
First I am not a licensed electrician.
My interest is that of an engineer, wishing if possible, to establish a "best practice".
It seems to me that there are divergent views on the exact choice of fluoros, incandescents, & LEDs.
My comments in no particular order:
1) Surely there is no place today for the use of incandescents in store lighting scenarios. Most incandescents are now Chinese & the quality is generally accepted as poor. This may or may not be true, but it is a generally held belief.
These devices are vibration & voltage sensitive, "extreme service" globes with reinforced filament support are available to counter vibration susceptibility. Generally higher voltage rated globes are also available.
2) Fluorescent lighting tubes remain, even today, as the best bang for buck, but exactly what life may be expected & what is the best voltage choice for a given supply is a matter that should be determined by the manufacturer. Whilst Chinese products are now available I believe US & European manufacturers products are still available & recommendations from such traditional manufacturers should be trustworthy. If your job involves maintenance of such fittings & tubes, I'd recommend making the appropriate contacts.
3) The labour costs of maintenance on fluorescents can be high, but it is probably better to do planned replacement of groups rather than periodic replacement of outages. Most definitely the change date should be recorded on the tube or fitting - knowledge is power.
4) LED's I believe should not yet be considered for other than experimental purposes in a commercial applications. They are generally of Chinese origin & utilise electronic components subject to considerable heat. Most lighting engineers commenting on the web believe the electronics are failure prone at a life well below that claimed. You might get 5000 hours but anything more is hope based.
I'd be happy to see myself corrected by anyone with fact based experience.
Store lighting
