ptonsparky
Tom
- EC - retired
Then you would really cuss me out if you ever follow behind me in a control panel.![]()
Not so much if both ends are labeled and there is a current drawing. Otherwise snip, snip.
Everything is labeled, drawings include full schematics, parts list, and point to point diagrams.
And then I have to read all that and interpret it and get a headache, or I can cut the ties and tug on a wire to see where it goes cussing the whole time.:rant:![]()
...Specifically, the temp. rise was several times higher...
Plus in a fire pump controller cabinet I wouldn't expect there to be much for loading except during a fire or during some sort of testing under real load.Several times higher?
Temp measurements don't usually work that way.
Yes, knowing you had temps significantly higher is useful, but I don't think you meant to say several times higher, did you? That would be hard to do.
