If you spin on an elbow and it only turns 3/4 of the way you'll back it off that 3/4 of a turn.
That's why I usually wait until my run is assembled and I'm screwing the elbow on before tightening everything. As I rotate the elbow, the loosest joint in the run will rotate, and all of the joints will eventually be tightened to the same degree.
Once I get to the point I believe I can not get another whole rotation, I stop at the correct position of the elbow. The result is that all joint are equally tight and, more importantly, I will not have to loosen any joint after I have tightened them.
