stickboy1375
- Litchfield, CT
Anyone else finding these buried in modular houses?
j_erickson said:Those connectors are now being made and marketed by tyco electronics. They can be concealed in existing buildings. I could have used about 20 of them in a recent remodel which would have eliminated junction boxes for about 10 circuits. They are advertised in EC magazine. I know most people will scoff at them, but in certain applications, I'd use them.
edit: See 334.40B
Indeed, they may be legal to use in that manner, but I would choose not to. I put these in the same category as backstabbing receptacles... legal but not always a good idea. I have replaced a number of these type connectors that have always failed in the same manner. The actual connector-to-connector interface stays fine. Where the insulation displacement prongs dig into the conductor, they heat up and fail. I'd be willing to bet that there are many 1000's of these type connectors sizzling away in homes across the US.j_erickson said:I know most people will scoff at them, but in certain applications, I'd use them.
edit: See 334.40B
stickboy1375 said:I consider them a junction box and therefore cannot be buried... but I don't know for sure if you can or cannot...
One prequalification seems to be that the cable has to be fished. I followed some ingenious sparky trying to use them for a kitchen remodel, where the layout was rearranged. He wanted to bury these at locations where the existing cables didn't reach the new intended locations. While the extentions from the old receptacle locations were fished, the existing cable onto which these modular home connectors were placed was stapled fast to the stud. This appears to be a violation of the code section sited above. I (think) the reason they only want you to use these on fished conductors is so that you can disconnect whatever it goes to at the far end, pull it back, and service the connector if need be. That's my guess anyhow. At any rate, these connectors have required service in the past, and there's no reason to think that they won't also need service into the future.iwire said:Yes in some applications you can.
stickboy1375 said:are these listed in the NEC? Or are you going by the manufacture specs?
Jim W in Tampa said:This sounds crazy.They go bad but can be concealed but a junction box cant be.Looks to me like just a plug and receptacle.But then mobiles have done cheap wiring for as long as i can remember.
j_erickson said:Jim, I bet you still solder your splices.![]()
