kwired
Electron manager
- NE Nebraska
- EC
I was going to chime in with the efficiency thing. No motor is 100% efficient, 746 kw per horsepower is the output rating, and that is assuming you are driving rated output load as well. Regardless input power will always be higher than output power. Then power factor will still result in higher VA than actual watts.No, use square root of three.
Then there is efficiency, so input KW is greater than output KW always! Or you invented a perpetual motion machine....![]()
