kwired
Electron manager
- NE Nebraska
- EC
Thing is owner maybe thinks just the bus bar would be less expensive - thing he doesn't necessarily know is they are not readily available as a replacement component. Even if you could order one, there will be a lead time and may still cost more then if you bought same panel from stock and swapped parts out of it, presuming same panel or one close enough is still being produced. Which I do believe Square D still makes panel interior that will directly fit in the enclosure in the OP.He's insistent? Is he an electrician?
