jwelectric
- North Carolina
looking at the pictures we have a 800 amp main breaker panel that has a bus bar tap kit installed that is supplying another panle installed beside the main.
the second panel is fed through PVC conduit and there is no grounding conductor installed in these conduits.
Is this second panel allowed to be bonded to the grounded neutral that is tapped from the first panel and no other path installed for fault current?
