Does anyone know who makes this? (see picture highlight - yellow wireway), what is the technical term for it? Is it called bus bar trough? so contractor can terminate the wiring on the internal bus bars? Thank you.
Does anyone know who makes this? (see picture highlight - yellow wireway), what is the technical term for it? Is it called bus bar trough? so contractor can terminate the wiring on the internal bus bars? Thank you.View attachment 20800
You're looking for a tap box. Here is an example: https://www.milbankworks.com/getmed...-c6faa5ee077a/flyer-multiposition-tap-box.pdf
But for an installation such as shown there are often better ways to do this. At the point in the drawing you are showing this it is often done either with a panelboard. Or sometimes the genset is factory built with 3 main breakers on the machine.
