GerryB
- woodbridge, ct. USA
This older home has a 100 amp fused disconnect sw. The original panel or fuse box was replaced with a 200 amp mb panel. Still protected by the 100 amp fused disconnect so ok. The question is can you use the 200 amp Buspar rating for the backfed breaker even though it should actually be a 100 amp panel
Sent from my SM-G930V using Tapatalk
