For new MV busduct installations between transformers and Switchgear I typically see a grounding pad located at both ends of the busduct housing which I'm assuming is intended to have a bonding jumper connected between it and the switchgear/transformer.
When providing this bonding jumper which NEC table in Section 250 applies for sizing this bonding jumper? From what I can tell this bonding jumper should be sized the same ad the EGC size provided in 250.122?
This would mean for a 2000A rated busduct that was installed in a recent application this would require a 250MCM bonding jumper between the busduct housing and switchgear/transformer. Is this correct? This seems like an awfully large bonding jumper to have on the outside of an enclosure?
