I find it weird there is no prohibition of this. My common sense is telling me it's a bad idea, I don't know...Searching the NY Fuel Gas Code Chapters 3 and 4 for the word "support" yields a prohibition if the gas pipe is CSST, but I did not find a general prohibition for other gas pipe types.
Chapter 3 General Regulations: General Regulations, New York State Fuel Gas Code 2020 | UpCodes
UpCodes offers a consolidated resource of construction and building code grouped by jurisdictionup.codes
Cheers, Wayne
Yeah, if something manages to break the pipe, it's doubtful the NM is going to survive, but MC might. Still, now you have gas and an ignition source next to each other.I find it weird there is no prohibition of this. My common sense is telling me it's a bad idea, I don't know...
I tried looking and there is none. the only thing that comes close to it is 300.11 but it doesn't tell you anything about electrical cable cannot be supported by foreign systemsDon't make me look for the article, but isn't there one that says that cables and conduits must be supported independently and not be attached to plumbing, sprinkler or mechanical systems?
-Hal
6703. Responsible charge of work defined
The phrase “responsible charge of work” means the independent control and direction, by the use of initiative, skill, and independent judgment, of the investigation or design of professional engineering work or the direct engineering control of such projects. The phrase does not refer to the concept of financial liability.
The answer would appear to be no.I saw a electrical power cable supported by a gas pipe. Is there anything in the code that prohibits this?
Nope.Don't make me look for the article, but isn't there one that says that cables and conduits must be supported independently and not be attached to plumbing, sprinkler or mechanical systems?
-Hal
