Can someone please direct me to an old thread or give me some examples of how a cable would be capable of transmitting gases?
I have a C1 D1 area with a C1 D1 Rated 208 Breaker Panel that I need to run an S/O Cord into. The cable will originate from a C1 D2 area.
Will the Cable Jacket need to be removed (center stripped) thru the seal-offs for this run of cable so each conductor can be packed and poured around? Or can the cable jacket be left intact since the cable will terminate inside the sealed C1 D1 Breaker Panel?
The cable will pass thru a seal-off at the panel and another at a nearby wall that the cable passes thru into the D2 area.
The cable is American Geoxal-125 Marine Shipboard Type Cable.
Thanks.
Thanks.
