Cable Cutters
ken44
Austin, TX
I have a large job in progress that will require cutting large diameter copper wire (4/0 through 500 KCMIL) many times and was trying to cut labor costs and provide better access to make the cuts by purchasing a greenlee gator-battery powered cable cutter with the open jaws but when my boss saw the price, he wanted to know if it were possible to purchase a cable cutter powered with 120 volts so I googled it and see that there are some other closed-jaw models available, unfortunately, they still cost over $2000. Any suggestions?
drbond24
Get one of these:
And then get a guy with arms like this:
Problem solved.
:D
Seriously, though, unless physcially having enough room to use it is a problem, cutting #4/0 through 500 MCM with a regular cable cutter isn't that hard. I've cut 750 MCM several times before and I'm an engineering nerd.
Fulthrotl
~Autocorrect is My Worst Enema.~
these work excellently, but again, aren't cheap. they are i think around
$1,400.
here's a link...
http://www.linemenssupply.com/pdfs/142_143.pdf
shockin
I can guarentee you that a "pie" knife is much better then anything else you can purchase. Unless you are cutting wire larger then 750 copper a pie knife will go right through it.
The guys in the field always think you need to buy them expensive and fancy cable cutters.
A pie knife is faster and cheaper and less maintance, why would you buy anything else.
charlie
Indianapolis
I was about to suggest ratchet cutters as well. Our linemen have them and some of our underground crews have the short ones to use in manholes. :)
ultramegabob
Indiana
Okay, I have to admit, I have never heard of a "pie knife" or "big bunny ears" as being related to cable cutters, how about some pictures....
SiddMartin
PA
Lennox makes one that fits in my cordless sawzall and it's about five bucks I think, Just kidding, I saw that Ideal one today and it's pretty heavy when it's hooked onto the drill.
the ideal one will also go in reverse, but i agree that it is heavy. Ideal rep. brought one in to test out about 2-3 yrs ago.
